Has anybody had any issues where Bambu connect won’t import sliced files?
My bambu connect all of a sudden just started to act up. There are no error messages or anything, I either drag & drop or use the import button to find the sliced files but the software just does nothing. It is not crashing. It is just not importing.
I have uninstalled and reinstalled it, installed the latest beta version, rolled back to the previous version, restarted the laptop multiple times, all with no luck.
I wondered if it didn’t like Orca sliced files all of a sudden but Bambu studio exported sliced files doesn’t work either. Earlier on the day I had printed a bambu studio sliced file just fine via bambu connect. Even the exact same bambu and Orca sliced files I have printed previously via connect aren’t importing.
Sorry to hear that — this sounds frustrating, especially since the same files worked earlier the same
day. I’d like to try to reproduce this on our end. Could you share a few details?
- A short screen recording of the import attempt (drag & drop or the Import button), so we can see
exactly what happens — or rather, what doesn’t.
- Version info:
- The exact Bambu Connect version(s) you tried (current, beta, and the rolled-back one)
- Your OS and version (e.g., Windows 11 23H2 / macOS 15.x)
- The slicer versions (Bambu Studio / OrcaSlicer) used to export the files
- One of the sliced files that fails to import (a .gcode.3mf you’ve previously printed successfully
would be ideal, since we know it used to work).
- If possible, the Bambu Connect log files from right after a failed import attempt.
Hi,
Thank you for your response, unfortunately (or fortunately for me) it all just started working a week after I posted here. I didn’t do anything to fix it, it wasn’t working once and then suddenly it started working 10 minutes later.
- As it is now working I can’t replicate that issue anymore!
- I was using ‘Bambu Connect v2.4.0-beta’. It was working fine until it wasn’t. I rolled back to ‘v2.2.1-beta.2’ as that was the one I was using prior. And then I rolled back to ‘v2.4.0-beta’.
- OS is windows 11
- Bambu Connect was ‘Bambu Studio v02.06.00.51’, Orca Slicer was ‘Orca Slicer V2.3.2’
- ‘P2 L 1 A…’ is an Orca Slicer File. I keep getting error messages to upload a bambu sliced file (it’s 29.6MB but the forum keeps telling it’s too big? Even though the message says max file size is 500MB)
P3 L 1 A PRE_PLA_3h35m.gcode.3mf (6.5 MB)
4. I am not sure how to find the log for connect, so I shall need some guidance on that if possible.
Thank you for your time and help.
