Bambu Engineering Plate - really low adhesion
For the sake of information, I tried to print PA-GF from Bambulab (i.e. a PA6 with added glass fibre). Can it be considered an engineering material? I think so, come on.
The plate was washed with soap and water and dried with new clean paper (to avoid leaving any type of release residue)
PA-GF perfectly dried 3% filament.
I tried to carry out 3 printing tests on the same day (therefore equal conditions) with 3 different glues on the plate:
-Bambulab liquid glue
-Magigoo liquid glue
-Bambulab glue stick
Default print profile with only plate at 110 degrees instead of 100 to (try) improve adhesion.
The printed piece is a square tile measuring approximately 4x4x1 cm.
The prints have all finished but in all cases there is warping on the edges, the least warping was obtained with Magigoo, the worst with Bambulab liquid glue.
I will try with new tests by applying brim or other glues or lacquer but honestly I’m disappointed and I really believe that this engineering plate is a project that came out badly (or maybe just mine is defective for some reason)
I immediately had the impression that it really had low adhesion with PETG and now it has been confirmed. Maybe it will work with other “technical” materials but at this point it’s a question of combinations and luck, something you don’t expect from bambulab.
I bought the Engineering Plate myself and have nothing but problems with ABS. I had already printed TPU with it and there were no adhesion issues, but that is well known since TPU adheres extremely well. I always clean the plate and use a fresh layer of 3DLAC spray. I’m going to try printing ABS one more time, this time without the 3DLAC spray.
With a ‘fake’ smooth plate from AliExpress, I had slightly better results, but even there, I had issues with warping. I simply think that you shouldn’t use any spray or glue stick with the Engineering Plate, even though Bambu recommends it. For TPU and PA (Nylon), sure. But I think for everything from PLA to PETG and ABS/ASA, it is unnecessary. I’m going to do another test print today without any glue in between.
I’m starting to suspect that the Engineering Plate is really just intended for technical filaments like PA, etc. Here is a tip: try using a Smooth Plate. I’m planning to buy an original one myself, but unfortunately, they are currently sold out. A friend of mine has a P1S and he uses the Smooth Plate exclusively for ABS with zero adhesion issues.
Strange. I have no adhesion problems if I use 3Dlac. I printed PLA, PETG, ABS and ASA with great success. However, without glue, I can’t get anything to stick to the plate! Even PLA ist just pushed around by the hotend!
I guess in this instance you would be better off using the smooth plate instead? If you are aiming to get a nice smooth finish on the bottom of the print?
I believe Bambu state you must use glue no matter what on this plate.
I thought that was the only use for the ENGINEERING plate, namely for ENGINEERING filaments … aka technical filaments like PA or similiar.
I would never have thought of using it to print PLA/PETG. :sweat_smile:
no so much , as BBL original “engineering plate” (light grey) which came with the X1C showed PETG as the suggested filaments
I’ve had good results with it and got caught when I bought spares : the new ones are not recognized, by the X1c, and if you try to bypass the warning, there’s almost no adhesion even with 10 additonal degres on the plate temp
The shop page showed the same change as for the H2D, about plate being supported by a comming firmware update see @MK4S_H2D post above
and plate recognition may not fix the problem if one needs to adjust some parameters (plate temp, or other)
Hi everyone,
I’m currently troubleshooting ASA warping issues on my Bambu Lab P2S and wanted to share my findings.
The Issue:
My prints look perfect for the first few layers, but once they reach about 1/4 of the total height, the corners start lifting aggressively. This happens even with a chamber temperature of 50°C.
What I’ve already tried:
Engineering Plate with 3DLAC: Corners lifted every time.
Engineering Plate (Deep cleaned, no spray): The warping actually became much worse.
Smooth PEI Plate with 3DLAC: Still getting warping at the corners.
The Theory:
I noticed that during these prints, the Chamber Fan was running at 100% in Filter Mode. According to the P2S specs, the “Adaptive Airflow System” can pull in air from outside or circulate it through the carbon filter.
I suspect that this 100% filter mode creates enough internal airflow to cause uneven cooling on the part. As the print gets higher and moves away from the 100°C heat of the bed, this draft likely causes the thermal stress that pulls the corners up.
Next Steps:
For my next test, I am going to disable the airflow as much as possible:
Chamber Fan / Filter: Set to 0%.
Aux Fan: Set to 0%.
Part Cooling Fan: Set to 0% (except for bridges).
Heatbed: Staying at 100°C.
I’ll report back to see if turning off the filter/chamber fan finally solves the warping. Has anyone else with a P2S noticed this?
50c is expected to have some warping for asa.
Bed Weld by Layerneer, you’ll NEVER worry again about lifting or adhesion. Apply on a fresh washed & cleaned plate, after every print just spray a sprinkle of IPA (91%) and wipe 1-2 times with a lint-free towel (aka wipe-alls) & enjoy sticky prints over & over.
I get about (5) prints off 1 application then I’ll repeat the cycle.
Respectfully disagree with the above. I happily printed many parts at 40°C chamber temp on my X1C, and in addition I have never used a single bit of glue stick in my printing life.
What always works for me:
- All fans off apart from part cooling fan. Should be nothing going on in there
110°C bed temp on a washed bed plate, not IPA wiped but fully cleaned and air dried
5mm outer brim on all parts.
Since using those settings I haven’t had any parts lift off the bed.
If you’re printing something with a large surface area with a high infill and large wall count it might be fighting against you.
that’s just a balancing game. Raising bed temp to 110c surely helps.
I thought I’d share the combination that finally worked for me with the Engineering Plate on my Bambu Lab X2D.
I print ABS, ABS+, ASA and ASA+, using everything from the cheapest budget filaments to more expensive brands. With this particular plate, my winning combination is a bed temperature of 110°C, a chamber temperature of 65°C, Creality glue stick and the chamber exhaust fan switched off throughout the print. I turn the exhaust fan on immediately after the print finishes.
Since I started using this combination, I haven’t had any more warping with any of those filaments. Even the cheap stuff stays down without the corners lifting.
For me, it’s the whole combination that makes the difference. Glue with the exhaust fan running didn’t work. Keeping the exhaust fan off without glue didn’t work either. Lower chamber temperatures or lower Engineering Plate temperatures also failed to give me the same results. On my machine, with this plate, all of these conditions together are what finally solved the problem.
P.S. I also leave the part on the bed until it has cooled to room temperature. By the time I go to pick it up, it has completely released from the Engineering Plate on its own.
