Bambu Lab X1 Specific G-Code
Hi, could anyone please help me with AMS retraction for A1, because of TPU, I use a splitter, but when I want to load the TPU, the other filament is in the way and I have to manually rotate the spool in the AMS to make space.
There is only this code in the end G-code section.
I don’t really understand the “S255” behind M620 and M621, could it be the thing that I’m looking for ? Is there even a way to do it ?
; pull back filament to AMS
M620 S255
G1 X267 F15000
T255
G1 X-28.5 F18000
G1 X-48.2 F3000
G1 X-28.5 F18000
G1 X-48.2 F3000
M621 S255
Thats a useless list for the most part because
A; its not official
B: its a theory.
G29 A performs fast five points mesh ABL (on X1C).
Hey, so I’m trying to adjust the fan speed for each layer of my print. But for some reason when I follow the documentation, I can’t get it to work. Is there a problem with the settings that is overriding my gcode? Or is there a problem with the documentation that I’m not aware of?
For your reference, here’s the code I used:
M106 S95
It’s “M106 P2 S95” for the aux fan. P1 is the part fan, P3 is the chamber fan.
Hey, I’d like to reset the layers that are displayed as a printing progress. I know that an M73 L1 command displays the layer line, that is being printed. The issue is, that it can only be increased and not decreased, so M73 L0 after M73 L1 is not going to have any effect.
Is there any known command to reset the layer lines?
Full list for gcode_claim_action
    case 0:
        return _L("Printing");
    case 1:
        return _L("Auto bed leveling");
    case 2:
        return _L("Heatbed preheating");
    case 3:
        return _L("Vibration compensation");
    case 4:
        return _L("Changing filament");
    case 5:
        return _L("M400 pause");
    case 6:
        return _L("Paused (filament ran out)");
    case 7:
        return _L("Heating nozzle");
    case 8:
        return _L("Calibrating dynamic flow");
    case 9:
        return _L("Scanning bed surface");
    case 10:
        return _L("Inspecting first layer");
    case 11:
        return _L("Identifying build plate type");
    case 12:
        return _L("Calibrating Micro Lidar");
    case 13:
        return _L("Homing toolhead");
    case 14:
        return _L("Cleaning nozzle tip");
    case 15:
        return _L("Checking extruder temperature");
    case 16:
        return _L("Paused by the user");
    case 17:
        return _L("Pause (front cover fall off)");
    case 18:
        return _L("Calibrating the micro lidar");
    case 19:
        return _L("Calibrating flow ratio");
    case 20:
        return _L("Pause (nozzle temperature malfunction)");
    case 21:
        return _L("Pause (heatbed temperature malfunction)");
    case 22:
        return _L("Filament unloading");
    case 23:
        return _L("Pause (step loss)");
    case 24:
        return _L("Filament loading");
    case 25:
        return _L("Motor noise cancellation");
    case 26:
        return _L("Pause (AMS offline)");
    case 27:
        return _L("Pause (low speed of the heatbreak fan)");
    case 28:
        return _L("Pause (chamber temperature control problem)");
    case 29:
        return _L("Cooling chamber");
    case 30:
        return _L("Pause (Gcode inserted by user)");
    case 31:
        return _L("Motor noise showoff");
    case 32:
        return _L("Pause (nozzle clumping)");
    case 33:
        return _L("Pause (cutter error)");
    case 34:
        return _L("Pause (first layer error)");
    case 35:
        return _L("Pause (nozzle clog)");
    case 36:
        return _L("Measuring motion percision");
    case 37:
        return _L("Enhancing motion percision");
    case 38:
        return _L("Measure motion accuracy");
    case 39:
        return _L("Nozzle offset calibration");
    case 40:
        return _L("high temperature auto bed levelling");
    case 41:
        return _L("Auto Check: Quick Release Lever");
    case 42:
        return _L("Auto Check: Door and Upper Cover");
    case 43:
        return _L("Laser Calibration");
    case 44:
        return _L("Auto Check: Platform");
    case 45:
        return _L("Confirming BirdsEye Camera location");
    case 46:
        return _L("Calibrating BirdsEye Camera");
    case 47:
        return _L("Auto bed leveling -phase 1");
    case 48:
        return _L("Auto bed leveling -phase 2");
    case 49:
        return _L("Heating chamber");
    case 50:
        return _L("Cooling heatbed");
    case 51:
        return _L("Printing calibration lines");
    case 52:
        return _L("Auto Check: Material");
    case 53:
        return _L("Live View Camera Calibration");
    case 54:
        return _L("Waiting for heatbed to reach target temperature");
    case 55:
        return _L("Auto Check: Material Position");
    case 56:
        return _L("Cutting Module Offset Calibration");
    case 57:
        return _L("Measuring Surface");
    case 58:
        return _L("Thermal Preconditioning for first layer optimization");
    case 59:
        return _L("Homing Blade Holder");                             // O1C
    case 60:
        return _L("Calibrating Camera Offset");                       // O1C
    case 61:
        return _L("Calibrating Blade Holder Position");               // O1C
    case 62:
        return _L("Hotend Pick and Place Test");                      // O1C
    case 63:
        return _L("Waiting for the Chamber temperature to equalize"); // O1S  O1E/U1   O1D/U2.5
    case 64:
        return _L(" Preparing Hotend");//O1C/U0
    case 65:
        return _L("Calibrating the detection position of nozzle clumping"); // N7
    case 66:
        return _L("Purifying the chamber air");
Have you tried setting M73 L1 after a higher layer count? The layer count for this purpose is 1 based so layer 0 isn’t a valid layer. If that doesn’t work try M73.2 R1.0 before M73.
Thanks, I’m going to try the M73.2 R1.0 command.
The M73 L1 command doesnt work. It will stay at the higher layer that was used before.
The reason I’m trying to reset the layers is an automtatic push off system that manipulates and combines the gcode of various plates and ads a push off sequence between the plates.
Right now I just combine all the layers of all plates and keep counting instead of reseting the layers. For example, if 3 plates are being combined, eacht with 100 layers, then it keeps counting from 1 to 300. Interestingly, on the printer there is the max layer count from the first plate displayed. for example 99/100. When it surpasses the max layer count, it looks like this: 233/100. Obviously, I’d like to change the max layer count to the actual total count of all plates.
Do you know by any chance where the max layer count is defined? I’ve been looking in the gcode file and in the other files provided in the 3mf file, but couldnt find it.
It is at the top of the gcode file. It is comments but the printer will parse it.
; HEADER_BLOCK_START
; generated by OrcaSlicer 2.3.1 on 2025-12-09 at 10:00:08
; model printing time: 32m 10s; total estimated time: 38m 37s
; estimated first layer printing time (normal mode) = 6m 26s
; total layer number: 999
; filament_density: 1.32
; filament_diameter: 1.75
; max_z_height: 23.88
; HEADER_BLOCK_END
Hmmm I’m not sure about that. normally the header block is being ignored. But I will check anyways. Thanks!
I tested changing the header block myself and it definitely works. It’s possible to print with just a gcode file rather than 3mf and this is where metadata is stored.
Does anyone know if to change the acceleration magnitude (part of how the speed setting on the printer works) the gcode is M204.2 or M201.2?
x1plus documentation claims it’s M204.2 x1plus-testing/Gcode.md at main · jphannifan/x1plus-testing · GitHub
But M204.2 is not present in any of the bambu machine start and end gcode but in the end gcode there is always this line M201.2 K1.0 ; Reset acc magnitude.
I was recently looking for this EXACT information (gcode_claim_action strings). How did you get it? Was it extracted from firmware?
It’s all in the Bambu Studio source code somewhere.
