Bambu Labs E1 is here
I tested the E1 at our company with an H2D Pro, which does not yet support automatic filtration, so I operated the filter manually.
During a 1.5-hour ABS print, the smell of ABS was still noticeable. I think people who claim there is no smell may simply get used to it because they remain in the room.
I started the print and filtration, left the room and spent an hour outdoors. When I returned, I noticed that it was significantly better than without filtration, but there was still a noticeable ABS smell, which raises some concerns about air quality.
Perhaps this is due to small leaks in the printer enclosure, or maybe the filter system itself is undersized.
My next step will be to connect the E1’s air outlet directly to the building’s exhaust ventilation system.
Did you guys mention, that for ASA, ABS and PC they have a special filter medium for E1 - so the standard filter in the E1 is not recommanded for these materials.
I use this kind of filter and all is good. In its nature I took care of an enclosed poop container. This should be the first measurement in sealing a printer for an absorbing filter system. You will get a proper result in doing the complete chain and not connecting an E1 and complaining about a patch on a whole carpet. So the negative pressure is enough to hold everything in the printer housing. As an example, I used a very thin and soft insulation tape from 3M to seal the poop container and the E1 adapter for H3C, this made it even airtighter instead of using printed tpu gaskets. I could go endless ahead. Just use your brain and come down to simple physics and it works so well guys.
I am guessing most of the time there is no tweeking needed. Have heard it automatically adjusts based on what is printed.
What does it index on? I am guessing the material name? Is there any problem with 3rd party filaments? Maybe it is an option when defining the filament. Where are any adjustments made? Sudio, Handy, Printer, E1?
What about multi material builds. How does it know how long to come on for? Lets say you have a PLA/ABS print. Does it only go into high when printing the ABS? Maybe for a time After ABS is extruded. Thinking most of the print is PLA, and little ABS.
I am guessing the life span of the cartridge will depend on how long it is in High mode and how long it is in Low mode. Where is the replacement notification?
All is provided in the magic of Bambus firmwares. Even the E1 will get frequent firmware updates when necessary. There is no guessing needed, if you replace the filter the only thing to do is to tell this via software option and the calculation starts again.
The lifespan goes over the operation speed ahead and depends on the printed filament. All specs are clearly written in the manuals.
What tweaking? Last topic was about airtightness and leaking odours.
The tweaking I was referring to is if you are using non-Bambu filament, or prefer more or less than the defaults dictate.
Higher flow rate would create more vacuum in chamber, reducing leakage from gaps in housing. Also requiring more chamber heat energy.
