Hello,
I tried eSun PLA+ and GST3D PLA+ and Bambu PLA filament
First I started with the standard Generic PLA Profile. and 35C
After that failed, I gradually increased the temperature by 5 degrees, to 60C.
Between tests, I’ve used the same filament with other build plates (Cool Plate, Texture Plate, PEX, etc.)
So the filament settings are fine.
I have to say I have the latest beta firmware on my printer but I don’t think it matters that much as all other plates have really good print plate adhesion.
… and of course I test both sides, my first idea was, maybe one side is not working or defect …
I am using Sunlu pla plus and sunlu tpu. Using the standard cold bed settings. Probably you have a bad plate or adhesion went bad quickly. ps: You tried both sides?
LOL… open a support request ticket with BL’s customer support services…and address them your questions… perhaps, you’re lucky and will get the answers you’re looking for.
Definitely it’s not the same plate. I know because i had the foresight to purchase 4 additional sets of build plates right after the delivery of my X1C, and a few months later BL has stopped producing/delivering cold plates, replacing them with (what BL calls) “satin plates”. Ordered one for testing and learned (the hard way) that’s not the same thing with the cold plate… You may try using it as a cold plate (keeping the cold plate settings in your Bambu Studio), and see the print results.
That makes sense, if it is a newer plate than the cool plate. Also I can’t find the cool plate any more in their store. Also not the replacement sheets.
I’d try first without, a test on one half, and with glue on the other half. Same print on both sides, and then you can determine which method works for you.
