With THAT much memory, why not try a different approach ?
Install a VM with Windows and what you need for 3D printing.
Give it just 16GB of Ram and see if it works.
I have 64GB machine left running but it is basically only used as a VM environment and for testing things, never had any slicing problems inside the VM.
Configuring it for proper network use can be a bit of pain though.
Exception code 5 means that the program tries to access a memory which does not exists or which is not assigned to this program. Usually an unassgned pointer or a memeory location is used after it has been freed.
The error is not necessarily in the slicer, could also be in a system library.
Because you have computers where it does not crash I would load the program on both machines and then use the process explorer from sysinternals to check which dlls are loaded. And compare size and version of corresponding dlls. Also the directory from which it is loaded.
Might be you get an idea what is too new or too old. Could also help, if you change the path variable in environment.
Good luck!
same Problem here with 4090 and i9 14900k + 32GB Ramā¦
For me, bambu studio also crashes on my Mac Studio when it is sliced and I try to print it. Bambu studio asks to restart and when I do this and go to device it is busy printing that sliced print.
Bambu Lab please create a stable bambu studioā¦
Couldnāt help it and used a spare all in one computer to set up Bambu Studio on it.
Why? BECAUSE !
I started with an old Win10 installation disk.
Slicing a massive dragon head with an impossibly detailed mesh worked great - but took almost 30 minutes to complete.
Than I let Windoofy check for updates - JUST for the hardware by manually going through the lot in the device manager.
After that the slicing was MUCH faster but out of 10 attempts crashed at some point.
Once even Studio ended in the digital nirvana and became unresponsive.
Letting Windows itself update (home version) again let the slicing work fine and the time was down to about 12 minutes.
So both the hardware drivers and Windows update status CAN affect how Bambu slices - or failsā¦
And mind you this computer is considered vintage - HP AIO from the g600 series LOL
Anyway, after adding some of the usual candidates things again got bad.
A trial version of Photoshop, some Cad and designs programs, a few browsersā¦
Did you ever notice how many libraries and such that Windows uses and shares with other programs get changed when installing things ???
Visual C++ can be a nightmare once messed up often enough and without the app installing it checking previous requirements.
And the list just goes on and on, especially with what the open source community provides.
Suddenly a program that HAS its own libraries or such canāt access them because the Windows path variables or other settings point to a different versionā¦
Letās just say both Microsoft and software providers love to create a messā¦
In terms of 64GM of ram or moreā¦
YES, there is higher chance of things going wrong if you past the 32GB.
But this again comes down to the above issues.
It is one thing to keep your system up to date everywhere but a totally different story to make it a match, especially if program updates keep messing with libraries and other vital things.
I said it before but ā¦
IF you have more computing power and RAM than what any slicer could need give a VM a try.
In there YOU are in control ![]()
Means you can install just the pure basics, like just the slicers you need.
If properly configured you can access all else that is outside the VM as normal.
Windows can update, programs can do the same but your VM wonāt be affected by itā¦
Iām having the same issue, with all of my slicers pursha Creality and bambu, I can get certain files to slice and others canāt, I tried dropping the triangle count and got a model to slice in Bambu but crashes other slicers and it looks really bad now because it lost its quality I have tried smaller models and tried doing a lot of the stuff in the replies above I have a 14700k i9 on a brand new motherboard with 64gb ram and a 3080ti. I feel so lost and clueless and Iām very disappointed because I canāt use my brand new p1s
Update I figured out a fix , my cpu was using too many cores and Uber task manager, details and set affinity selecting my first 7 cores I am able to slice perfectly fine now and this fixed all of my slicers, I hope this helps yall
Try setting your affinity
Thank you good sir, this worked for me too with my 28 virtual cores.
Set your power limits correctly in the bios, that fixes the issue, seems board partners are cranking up the power limits by default.
I9-14900KS
96gb DDR5 @ 6600mhz
RTX4500ADA
Brand new, just installed bambu studio and crashes my whole computer every 2 minā¦
Small model, nothing crazy, nothing else openedā¦
I was having issues with crashing nothing working - Today I started the Bambu Slicer went to the Task Manager - Properties and set compatability mode to Windows 8. I did not crash as of yet testing out some more.
Just updated to 1.9.1.66 today and had the same issue. Moving to Win 8 Compatability worked for me.
Ryzen 7800X3D
32GB DDR-6400
Windows 11 Pro
Updated Bambu Studio to 1.9.1.66 with the same issue. Turn on the efficiency mode in Task Manager worked for me.
Processor 13th Gen Intel core i9-13900k
Ram 64 gb
GPU Geforce RTX 3090 TI
Windows 11 Pro
i was thinking somewhere i read to make sure your GPU is rendering instead of cpu dont know where the setting is or was but something to look into, thinking it defaulted to cpu or something
Same issue, been a week of crashing left and right. 4090, 64gb ddr5, 14900k⦠p1s⦠ive apent hours fiddiling with various sizes and models⦠crash at 35% on slicing like clockwork.
Ill try windows 8 compatibility, dont know what that is or how tobdo it but ill google it. I run windows 11.
@collincoons64 Thank you for the fix. THIS WORKED!!!
You were right, I just didnāt know how to do what you mentioned, Iāll include the how to for those that donāt know. I am not savvy so google was my friend.
UPDATE
How to Set Affinity in Windows 11
- Step 1: Open Task Manager First, right-click the taskbar and select Task Manager.
- Step 2: Locate the Process Next, go to the Processes tab and find the program you want to set affinity for.
- Step 3: Open the Processā Context Menu Right-click the selected program and choose Go to details.
- Step 4: Set Affinity
- Step 5: Choose CPU Cores
(Select 7 Cores Total)
One downside of using this Affinity trick is that you need to do it everytime you start Bambu Studio. Process Lasso can help with this. It is a little program and it is free.
I canāt add an url but if you do a Google search for āProcess Lassoā you will find it. Bitsum is the company who made this program.
Thank you very much for the step-by-step!!!
You can use āCoreDirectorā to automate what @collincoons64 and @TFS247 are telling you here.
I didnāt want to repeat the steps, TFS247 descibes above. With this little tool you can automate it and have Bambu Slicer only use the first few cores (in my case, slicing is even faster with the limited number of cores).
