I am on CachyOS (Linux arch based distro) and due to system updates, I cant launch Bambu Studio anymore. Yesterday it workd like usual, no problems at all.
Unfortunately, I cant rollback the updates from yesterday.
Here is the error, that the terminal shows, if I want to launch Bambu Studio:
[2025-06-20 17:37:35.903947] [0x00007ff5c932b480] [trace] Initializing StaticPrintConfigs
add font of HarmonyOS_Sans_SC_Bold returns 1
add font of HarmonyOS_Sans_SC_Regular returns 1
I ran into the same issue.
Deleting the folder “com.bambulab.BambuStudio” in “/home/USER/.var/app/” fixed the issue for me. But I had to configure BambuStudio from scratch. Perhaps it’s possible to save certain config files to preserve those user information but I didn’t really try .
After those 2 commands, I was able to run the appimage, but it did make me set up everything again and reconnect my account.
but, your installation may vary, so I will show you how to determine where your files are. Run this command
find / -iname “*bambu*” 2>/dev/null
This will show you all the folders with the word “Bambu” in them (case-insensitive). From this output you should be able to determine where Bambu stores its files on your hdd.
This is still happening on Kubuntu, at the end of 2026. What I found was that the BambuStudio.conf file is getting corrupted or something. It shows up as 0 B.
I only had to delete that single file. Not the directory. After doing so, started the app and it came right up, creating a new conf file.
I previously synced my settings with Bambu cloud, so no loss.
Same here on Fedora 43. Spent all yesterday trying to track down issues after an OS update and then found this thread and saw that my .conf file was also 0 bytes. Deleted and re-ran the appimage and all good again after first run wizard and profile sync
