I installed the latest update and configuration recently. I tried adding a text modifier like I normally did, it shows as there and the color is set, then as soon as I slice the part, all text and the wipe tower is then removed from the part.
Is anyone else seeing this?
Share an image or the file you are working with. Could it be that the text its a negative part or its not deep enough (0.3mm to be sure) in the model to appear in the the layers?
Thanks for responding Marin. i normally set a depth of 0.6mm to prevent bleed through.
text settings
Pre slice
After slice.
Can you share the file?
Have you tried instead of doing it as a modifier doing it as a part and switching the color of the part?
You can also do this by selecting the modifier right clicking and change type.
