I experimented with changing the Print Sequence from the default setting of By Layer to By Object. Resulting with multiple errors informing me that the parts were too close to each other and suggesting to use the Auto Arrange tool. When I did, the tool spaced the parts widely, leaving only 4 small parts per plate on many plates. Why?
Because they have to be spaced far enough apart that the toolhead will not collide with already printed parts.
Also this is not a beta feature this is available in normal Bambu Studio also.
Bambu Studio will show you the areas that are needed for “by object”.
Yep, the only thing that it sadly doesn’t do is adjust those if they ae shorter then the space between the nozzle tip and fan ducts, which would be usefull when printing many small parts like pins or dowels.
