gRby
December 10, 2025, 12:30am
1
Hi,
After one of the Bambu Studio upgrade, preview started to be wired. Currently I’m using latest version 2.4.0.70. At the same time in Orca Slicer preview is ok.
Preview looks like is composed from triangles.
I will be very grateful for some help
Crover
December 12, 2025, 4:38pm
2
I have the same problem… Please help
There is a current bug report for this issue.
opened 10:02PM - 05 Dec 25 UTC
bug
### Bambu Studio Version
2.4.0.70
### Where is the application from?
Bambu La… b Official website
### OS version
Windows 11 Windows [Version 10.0.26200.7309]
### Additional system information
Host Name: HW-PC-BLIU1
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.26200 N/A Build 26200
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: boang.liu@gmail.com
Registered Organization: N/A
Product ID: 00330-81476-07591-AA551
Original Install Date: 12/12/2024, 4:40:35 PM
System Boot Time: 12/2/2025, 9:24:36 AM
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: ROG Strix G15CE_G15CE
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 167 Stepping 1 GenuineIntel ~3600 Mhz
BIOS Version: American Megatrends Inc. G15CE.312, 4/29/2024
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
System Locale: en-us;English (United States)
Input Locale: en-us;English (United States)
Time Zone: (UTC-06:00) Central Time (US & Canada)
Total Physical Memory: 16,221 MB
Available Physical Memory: 2,473 MB
Virtual Memory: Max Size: 39,773 MB
Virtual Memory: Available: 7,009 MB
Virtual Memory: In Use: 32,764 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\HW-PC-BLIU1
Hotfix(s): 5 Hotfix(s) Installed.
[01]: KB5067931
[02]: KB5054156
[03]: KB5070311
[04]: KB5067035
[05]: KB5071142
Network Card(s): 8 NIC(s) Installed.
[01]: TAP-NordVPN Windows Adapter V9
Connection Name: Local Area Connection
Status: Media disconnected
[02]: OpenVPN Data Channel Offload
Connection Name: OpenVPN Data Channel Offload for NordVPN
[03]: Intel(R) Wi-Fi 6 AX201 160MHz
Connection Name: Wi-Fi
DHCP Enabled: Yes
DHCP Server: 192.168.4.1
IP address(es)
[01]: 192.168.5.183
[04]: Intel(R) Ethernet Controller (3) I225-V
Connection Name: Ethernet
[05]: Wintun Userspace Tunnel
Connection Name: Tailscale
DHCP Enabled: No
IP address(es)
[01]: 100.102.195.104
[02]: fe80::9a6b:737b:ec0c:3f89
[03]: fd7a:115c:a1e0::ad01:c368
[06]: Bluetooth Device (Personal Area Network)
Connection Name: Bluetooth Network Connection
[07]: WireGuard Tunnel
Connection Name: NordLynx
DHCP Enabled: No
IP address(es)
[01]: 10.5.0.2
[08]: VirtualBox Host-Only Ethernet Adapter
Connection Name: Ethernet 2
DHCP Enabled: No
IP address(es)
[01]: 192.168.56.1
[02]: fe80::30bc:322a:8c2f:c629
Virtualization-based security: Status: Not enabled
App Control for Business policy: Enforced
App Control for Business user mode policy: Off
Security Features Enabled:
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: Yes
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
### Printer
Bambu H2D serial 0948AD560502510
### Printer Firmware Version
01.02.02.00
### How to reproduce
1. Insert any model into the Prepare tab. You can even right click and add a primitive shape or model there.
2. Slice Plate
3. Go to preview tab and you can see the sliced model
### Actual results
<img width="1914" height="996" alt="Image" src="https://github.com/user-attachments/assets/73532529-e11f-43bf-a2b9-265346cd1952" />
<img width="1915" height="996" alt="Image" src="https://github.com/user-attachments/assets/8df62b11-20d6-45e3-bc47-0b41529a7909" />
### Expected results
Expected to have the extrusion lines be filled in. Orcaslicer on the same PC shows it correctly.
Reinstalling Bambu Studio does not do anything.
### Project file & Debug log uploads
This is the saved 3mf file of the resultant sliced model.
[3DBenchy.zip](https://github.com/user-attachments/files/23971406/3DBenchy.zip)
This is some log files of Bambu Studio
[BambuLabLog.zip](https://github.com/user-attachments/files/23971693/BambuLabLog.zip)
### Checklist of files to include
- [x] Log file
- [x] Project file
gRby
December 13, 2025, 1:02pm
4
Thanks for info!
I hope to see the fixed version very soon.
gRby
January 28, 2026, 8:01pm
5
Problem was fixed with version v02.05.00.64, and return with v02.05.00.66
This has been frustrating me! I am a new user since December and see countless videos online showing beautifully rendered slicing models as the slider is drawn down. Mine is a pretty much useless wire frame triangle image. I have been searching for a setting I have wrong to no avail. Sorta glad to see it’s not be but a software issue. I’m running the latest version of Studio.
Any information on this would be appreciated.
JVK
gRby
February 4, 2026, 10:20pm
7
In Preferences disable option “Enable advanced gcode viewer” and restart the Bambu Studio.
This is temporary solution but it works.
Actually I can’t find any info what this “advanced gcode viewer” means…
Thanks! That made a difference, but still is a bit weird. I can live with that until they get it fixed.
JVK
