My A1 is scraping over the printbed fist it calibrates and then the nozzle scratech over the printbed filament cant really come out and i destroyed allready one of my buildplates, I havent changed any slicer settings and it happens wich every filament i have.
Same here, I tried the bed tramming and factory reset but no luck! Anybody have a solution?
Scratches on the print plate are normal if they’re meant to clean the nozzle: It’s always the same spot.
…or do you have scratches running across the surface?
- Perform a factory reset and recalibrate everything. Follow the instructions carefully regarding when and how to place the printer plate. This often happens when you calibrate the printer without the printer plate.
Hi
I have the same problem, on the first layer the nozzle don’t print because is very close to the platform, maybe is a force cell problem?
