Bambulab H2S print issue after filament change
Hi eveyone,
I have encountered an issue with the H2S printer when I print in 2 or more colors.
It seems that after color/filament change the first layer after the change is not extruded correctly even thow I can see the extruder wheel spining. Looks like the material is not flowing properly thorugh nozzle. The nozzles were cleaned (cold pull) and swapt also with a new ones.
With prime tower enabled I can see this issue on the first 2 lines of purge inside the tower.
See test below:
Scenario: Material Bambulab PLA Basic.
Object: square - 1 layer thick with another 1 layer thick Text with word ‘Text’ on top(2 layers in total).
Settings No prime tower.
Flow rate 0,98 → 1,05 tested so far
PA K:0,018 . Flow Dinamics Caliration: Auto/ On and Off all tried so far
Nozzle 0.4mm Standard and 0.2 mm Standard
Temperature tested for first layer 215, 220, 225
Results:
Flow dinamics Calibration Off, K:0,018 - Square si printed OK and from the word ‘Text’ only letters ‘xt’ are printed. During printing letters ‘Te’ there is no extrusion
Results:
Flow dinamics Calibration ON, K:0,018 - Square si printed OK and from the word ‘Text’ only letters ‘ext’ are printed. During printing letter ‘T’ there is no extrusion.
Anyone has any idea what can do to make this workwithout prime tower?
Thx in advance!
