I have a problem using BS on my laptop. The resolution is set to the panel’s maximum (2200x1440). When I adjust the text scaling to 125% or 150% to make the letters more readable in the menus, the left sidebar that shows speed, power, etc. seems to get stuck and only displays partially. Any solution? (I’m using the latest version 2.2.1.60)
Have you tried advanced scaling in app properties? Here is a post I made some time ago that may help.
I’m not sure which tab you are in that shows power? The Prepare/Preview left sidebar should be adjustable.
In Windows, you can adjust text (Settings>Accessibility>Text size), and you can also adjust overall scale (Settings>System>Display>Custom Scaling), which also affects text size.
I found I needed to experiment with both to find a happy medium. The text in some apps is not affected by the Accessibility setting, so I use Custom Scaling to set the overall size of things and then adjust Text size if needed.
Yes! Thanks! Finally got the solution unchecking
“Override high DPI scaling behavior”
