After updating to latest version (V2.4.0.70) I can slice the model but I can not tell it to print it.
Setup send me to an animation that wants to select Octoprint and a non Bambu printer.
Yeah, I had this happen as well. None of my printers came over. I uninstalled and installed an older version, verified my printers were in the devices tab, then installed the newest version again. No issues the 2nd time.
For some reason the new version doesn’t have a printer selected on the Prepare tab. You need to have a Bambu printer selected on the Prepare tab before going over to Devices.
On the Prepare tab, select the Printer drop down and choose your printer. That’ll fix it.
I had nothing in my printer lists in the prepare tab. Just fyi, no devices came over. I have 5 printers that all have individual custom names that will show up in the prepare tab normally.
Thanks for the information, I still have not got a reply on my trouble ticket to Bambu Labs.
I swapped to a different computer that had the older versioin still on it to back operational again.
Then restored a restor point on the second computer, then updated to the new version that now seens to be working.
Hope they get evrything worked out, I have a second printer coming in on Monday (P2S combo) will check the multi-printer operation.
Only other that I run into is an ocasional change in the IP Address. It should be locked to the MAC Adress in my router. It would help if I could set a static IP in the printer firmware.
