Hello everybody. Until now everyhting came out just fine from my new H2D. Until I printed this model. I am seeing artefacts shortly before the rounded corners are starting. The pattern seems to repeat itself with a distance of 11mm.
Now the tricky thing I cannot get my head around is if I rotate the object 90 degrees, I do not see these artefacts. Nor on any other prints I have done in the 60hrs.
There is no difference in speed, flow, temperature or fan speed accoding to the Bambu Slicer, also no internal structures at those heights.
Although it seems minor, I am a bit concerned if it is hardware related and whether I should contact support. Is this within the expected margins of the FDM printer.
Things I tried:
- Different filament (both Bambu PLA)
- Dryed filament
- Flow calibration
- Did the belt tension procedure
- Cleaned an greased the lead screws just in case
- Full calibration run
Any advice where to look, and what that could be causing is really appreciated.
box_sample.3mf (39.3 KB)
