Hi, I have been trying to get my new A1 mini to work properly, but I keep getting very noticeable bands on the Y axis face only. Other faces are fine.
I have run multiple calibrations to no avail. Searching around, I found some discussion on the Y belt being possibly loose, or on some screws being loose.
I tightened all the screw on and under the plate, rerun the self-calibration, but no effect.
Then I tried to follow the official maintenance documentation (A1 mini Maintenance Guidelines | Bambu Lab Wiki) to see if the belt was loose, but I can’t figure out what I’m supposed to do.
I opened the rear panel, loosened the bottom screw as the instructions say, but then they say to push on the block? Nothing moved at all in any direction. I undid the bottom screw completely and tried again, but it’s all solid and nothing moves. Still, I retightened the screw and calibrated again, but no change.
Any advice? I can’t tell if I’m missing some obvious thing to do.
Also, I guess the problem could be elsewhere, but the fact I only get this print defects on the faces corresponding to the Y axis movement seem to suggest it has something to do with it.
