BBL Refills really only 930gr ( or less?)
Hey so I just bought a bundle of 10 refills from the website, europoean shipment.
Everything everywhere states refills are 1kg.
When im about to weigh the refill still closed with cardboard nucleus and desiccant before i mounted on a reusable spool i notice the weight is off at 976grs, like i wrote before still weighing the desiccant and spool nucleus.
Then weighing the cardboard package box + the shrink plastic + the desiccant theres 71 grams.
If i weigh a closed sealed refill box of other color i have 1005grams.
I just bought 10 refills this means 700 grams less total plus the cardboard nucleus x10 instead of 10kg of refill filament
What’s going on?
Pictures and videos
Video:
https://www.dropbox.com/scl/fi/doqm6wh3skenep9d36am6/20251024_014303.mp4?rlkey=sawx4p3osxn3e7s57nautfgsy&st=4zxh0pl0&dl=0
Screenshot_20251024_024613_Gallery|233x500
That is the weight before you soak it in water for 24 hours to get it ready for printing.
I have noticed this for awhile. I keep track of my filaments in an excel doc and seem to get shorted by about 25 to 30 grams. I always just chalked this up to how filament usage is calculated. 70 grams seems excessive.
Sounds like Ill be measuring some filament tomorrow.
Yeah I mean. I bought 10 refills that amounts to more than 700 grams less… .
I can’t even imagine if a spooled filament is also total 1kg or 1250gr…
If the spool alone is around 250 grams… That makes every spool only have 750gr of filament not 1kg…
I feel like I’ve been tricked…
I’ve opened a ticket about this I’m wanting for a reply
I thought you were referring to a refill not a full spool?
Blockquote
:joy::eyes::skull:
Btw this forum architecture is crazy…
I am, I’m just referring to another possible problem existing with spooled filament
I say weigh all of your spools and out some numbers in excel.
I would be curious to weigh the cardboard insert as well to see what that contributes to the weight.
This doesn’t seem right.
Could you please open a ticket so our team can investigate further and offer a solution?
Inside the cardboard core of the spool, there should be a code. Please also include a picture of it in the ticket.
Thank you
I had 4 rolls of refill still in the closet, purchased sometime in 2024
They were between 1065 and 1085g, unboxed but still wrapped.
I know it doesn’t. It has been opened.
Btw there’s no category for filament issues regarding quality/ weight issues
Yeah just did weigh a empty nucleus… 35grs less to add to subtracted filament weight.
I’m waiting for the support reply. So far nothing
Here’s a closed/ sealed box with only 1005gr
Now remove cardboard box, vacuum shrink plastic, desiccant and sticker (71gr) + nucleus (35gr).
That’s 105gr less just right there
