Beam Interlocking Problem
Hi folks,
I am trying to print some pieces (White) with TPU strips (Black).
I have done this successfully before, but for some reason this time, the TPU strips are extending out into the infill after slicing, which I do not want.
I load the pieces as a single object with multiple parts, because if I load them as separate objects then I cant use beam interlocking.
How can I get rid of this default mesh so my beam interlocking will work as normal?
Images and 3mf attached.
Door Frame Basic Final.3mf (42.4 KB)
Ok, so after some more trial and error attempts, this seems to be due to a glitch with painting parts.
  • If i paint the strips of TPU after adding the objects, it doesnt work.
  • If I use the Process dialog to select TPU for the objects after adding them, it does work.
  • If I paint AND use the process dialog, it doesnt work.
  • If I paint, then try to change back to a different material by re-painting, then use the process dialog it still doesnt work.
So basically, painting screws up bambu studios understanding of object separation.
Is there actually a reason/logical explanation for this?
