Bed calibrating
I tried calibrating the bed, and it went up fine, but when it started going down it just wouldn’t stop and made this awful grinding noise. I have absolutely no clue what’s wrong with it. I checked if it was stuck on something or something on the sensor and nothing was there. Does anyone have any idea what could be happening
To confirm, you homed the bed and it did the multi-touch with the extruder at the bed’s center before this happened?
When going downward, the bed is looking for a change in motor load to signify it’s bottomed out. Most often, there are debris either in the bottom area of the chamber or there are bits of filament in the little holes aroune the Z linear rails. Go in with tweezers and remove whatever is there, assuming you find something in one or more of them then try re-homing and try it again.
