Bed height wrong
Ok my filament got stuck while printing and after unclogging the extruder, i went to continue printing but the build is lower than the extruder, how do i get it back to the right height?
i tried raising the bed through Bambu studio but it popped a message saying to send it home which would not be good as it’s at 90% done and it would probably be in the way for the extruder to move about.
You can’t, the print has failed :S
The only thing you could do, is to print the rest of the print separately and glue the two parts together.
Mesure the height of the failed print. And in the slicer, cut the part at the same height and print the remaining part.
That won’t be possible as it’s one of these ( the outer part) Conoidal Spiral Illusion Fidget by Zurlingo-3D - MakerWorld
I’ll just have to try for the 3rd time.
PS: Any idea why i can’t post in other categories on this forum, Makerlab seems to be the only place i can post.
You should be able to post in all categories. When posting, be sure to post in the sub category that your post pertains too as you can’t post in the main category.
Ok, that must be it, didn’t realise they were sub cats and not straight posts.
