I’m so new to this I just let my P2S do its thing. The color sequence is a bit much at times, seems like a lot of poops. The leveling gives me a good feeling that things are good. But the poop when it is the same color is wasteful, IMO.
I wish CarbonForge would elaborate on how to make those changes. It would help a Newby like me.
If you are printing with a lot of colour changes and there is a lot of poop you can print into an object and make a fidget toy. It is actually rather easy and there are some really good tutorials. I’ll find one for you to try.
I was trying to find the model. It was just a figurine I wanted to try printing from the online Models. My first attempt at a multi color model.
When it was done, I had a warning about the poop chute. It had made a pile that backed up from the poop can I’d made for my P2S up until the printer apparently alarmed. The figurine was done, and I pulled the box and emptied it. But it is not a small catch can.
I just thought it was rather excessive pooping. The Mini Jesus came out real nice though.
While I’m bending your ear, do you know how I can post a picture in a post? I have two on my phone that was requested by “Badger” on my thread I started. Seems he didn’t believe I can print in Ludacris speed, and wants a picture. I haven’t found how to post any.
I run bed leveling auto calibration, once a day, if that. In general, the calibration doesn’t change a noticeable amount while the machine is stationary and regularly in use.
I disagree with the responses on this. The build platform sits on a set of springs. When you pull the plate off, you compress and extend those springs a little. There is friction, and the possibility that stresses that have built up from the previous print due to heating might be relieved. The platform may or may not end up in exactly the same spot it was in before, when you replace the build plate. The delta would be small, but if you ran a dial indicator across the plate it is probably going to show changes.
I let the printer do the leveling each time. Yeah, it takes a bit longer to run the job, but I know if I disturbed the platform it’ll be levelled-out. Ultimately, it’s less time than having to restart if the first layer fails because leveling is out of whack…
I think you have a good point. If I take the plate off then yes, I can imagine there is a lot of disruption.
Most of these prints for this project have been 21 minutes and I never take the plate off.. They are thin leaves and I just peel them off. I need 109 leaves for the lamp and there are only 4 or 5 to a plate depending on the style… and I am printing 2 lamps so I actually need 218 leaves…. lol… I sometimes felt that the bed levelling was longer than the print.
I did turn the bed levelling off for a while and found no problems but turned it back on after removing the plate for cleaning.
