Hi guys i’ve a discrepancy with temp set on material and temp reached during working ! For example i use ASA Polymaker and bed temp is setted to 100° but when started it reach 90° .
Where i mistake ?
Hi
I can only see this happening if you have custom settings.
So if you are using the default printer, filaments, etc., settings, and your filament presets are well defined in the software and printer, but your print runs with different operating conditions from the ones specified, something is seriously wrong.
I checked, and BL ASA, Polymaker ASA, and Generic ASA default filament profiles, as well as the one provided by Polymaker for PolyLite ASA filament, have 100ºC for bed temperature for all layers, so this shouldn’t happen.
ABS is the one which typically requires a 90ºC bed.
Ciao Jay i found where is the mistake . I use also Hips for support setted to 90° and ASA to 100° . Bambu not manage well the 2 temperature and keep the lower active . I’ve increased hips to 100.
