Beds making horrible noises
My printers been working just fine, but during my last print I heard some clanking noises, and when I returned to the prints, the head was covered in a blob of filament (so through an error).
Now if I move the bed back and forward whilst off, it makes a bad noise - not sure what it is - if something stuck in there or something broken. Also when starting to print there are some iregular noises/behaviour at the start (see video)
Any help would be very much appreciated!
Your much bigger problem is the X axis movement, you’re losing steps like crazy there.
How many hours are on your machine, and are you following the Bambu wiki directions on how to clean and lubricate your axes? When was it last done?
:-/ im not sure how many hours ive printed on it - but had it a few years (pretty much since they were launched). I lubricate the bed axis when prompted, but havent done the up down one before
Yikes.
Well, here you go, have fun!
thanks - yeah it only seems to prompt me to clean 1 axis for some reason. Ive got a feeling there might be something more at play though :frowning: .
I just set something to print, and after various unsettling sounds, it did actually start printing as I would have expected - except the priming strip as you can see is too far in. Does this give any more clues?
It means you’re losing steps, which happens when something is preventing full range of motion, which can include sticky guides.
Full cleaning and lubrication first, then additional diagnostics if required.
after looking at the maintenance page, Ive remembered that I do actually lubricate the left/right as well as back/forth regularly.
Im still getting an odd noise coming from inside the base when I move the bed back and forth though (im not sure it would be that obvious on video) .
Perhaps somethings got stuck or dislodges in there maybe? Would it be a big job to access it? :-/
I made a support ticket - and turns out the issue was som trapped filament under the Y guide rail. Thats a relief!!
