I have several times read mention of “Filament Calibration”. What is this? I don’t see a function for this in the P2S user-interface. Thank you.
in the slicer the tab “calibration”. no ?
Have you read through the wiki yet? This should answer most questions.
I think I found it. It is in Bambu Studio, under the Calibration Tab. It is called Flow Dynamics Calibration. Am I correct?
please note if you are using non bambu filaments you have to create the brand profile prior of all, otherwise you will end in a mess on profiles.
to do this you have to click on the gear sprocket on “project filaments” then select the “custom filaments” tab and create new.
do this before everything else.
after that you can calmly calibrate your new filaments. (in primis flow rate)
If you’re not search for troubles with CF,GF filaments or such, default flow rates should be good for now, there’s enough stuff to check for you already
