Best droopy cable supports?
Time has drooped the power cables on an A1 & A1 mini. The mini’s cable hung up on the attached handle print installed atop the tower. So, designing a cable support was mandatory. The first design in PLA for the tower side showed it’s not the same as the A1. These tower sided models clip onto the filament cutting boss and use a ribbon style spring with single clip cable holder on top. The toolhead side support uses the same ribbon & cable clip design attached to the base which slides over the toolhead’s cable boss. These are the same for each printer. Early results work as desired. What mod have you attached for cable support?
