Best PETG Glue
Whats the best glue or adhesive for PETG
I prefer JB Weld Clearweld 2-part epoxy for anything that absolutely-has-to-stay while being mechanically used.
If you’re just tacking things together, non-gel CA glue is ok. I find the gel type to offgas white haze because its so easy to overapply…
edit: It appears to me that you could be asking about bed adhesive and not gluing petg pieces together, so like, please dont use epoxy on your bed lol
Depends. I just use Bambu’s Liquid Glue, it works perfectly, and it lasts a long time. It’s not too sticky after you peel your print off the plate, either.
I am using a cheap no name glue stick with good results.
Are you trying to glue together 2 PETG parts?
Or talking about glue for the print bed to act as a release agent?
If surfaces mate cleanly, MEK solvent bonding is superior to gluing.
It’s all I ever use for PETG.
