Best practice for printing logo in first layer (2 colors)
Hi @RocketSled,
thanks for your reply!
Here’s the two test objects in Bambu Studio, both from above and below:
The left object consists of two parts (which have not been split). Part 2 has been assigned the second filament via object-based configuration (see highlighted part in the configuration tab on the left). Part 2 is two layers thick.
The object on the right consists of one part only. The letter is recessed by two layers, the ‘letter layer’ itself is only one layer thick and visible from above and below. I coloured this layer from above and below via the painting tool in Bambu Studio.
After slicing both filaments are being shown in the Preview tab and filament changes are shown correctly:
My expectation would be for the printer to pause when reaching those areas and ask for manual filament change (as is the case when using layer-based filament changes). The pause does not occur, however, the whole model is being printed in one go with a single filament.
Am I doing something wrong? Are there additional settings required to achieve the desired behaviour?
Thanks a lot for your help!
