I have some evidence that Sunlu and Anycubic are selling the same filament: both the spools and the anonymous printed labels attached to the spools look the same. Anycubic is usually less expensive though. So, if you like Sunlu filament, but want it for less money, you may want to look into it. I wouldn’t be at all surprised if each of them buy completed filament spools from the same supplier and simply put it in a box with their own brand name on it.
Hey I have a bambulab a1 mini
I bought a spool of sunlu PETG
Do you have the right settings for it?
Maybe as a configuration file ?
Thanks for your help
What is it that you prefer to 3DLAC?
I use Elmer’s Purple, there is no way I would pay $40 for that…JMO
Spot on Olias. Aquanet is my go-to on every plate, every print, and every filament (PETG, ABS, ASA, NYLON, TPU, and PC) that I run on my Bambu X1C and Prusa printers. Just a light mist and it just works for adhesion and removal. And I’m now using my Engineering Plate for all filaments because of the smoother surface over the gold PEI plate I have.
Washed the Engineering Plate with a 3M scrubby pad and Dawn dish soap and then lightly sprayed the palate with Aquanet and spray again before every new print, (washing the plate again after 30+ plus prints or as needed.) It’s been 2 years and hundreds of prints and not a single issue. Love my Aquanet so much I bought a case of it.
I print a lot with Sunlu PETG on my P1P (with printed enclosure and lid). I really like their PETG and use it for most of my prints.
I’m using 245C for first layer and 235C for the others. On the textured PEI plate I use 70C. If the print is going to run for more than a couple hours, I usually open one side panel or the chamber gets too hot.
I
These are my Sunlu PETG settings that work on the A1 with the 0.4 Nozzle quite well. I haven’t done any stress tests; the settings are focused on aesthetics.
- Temperature: 230°C
- Volumetric Flow: 17.6
- Extrusion Multiplier: 0.928
- Pressure Advance: 0.042
- Maximum and consistent print speed: around 220mm/s
Speed: Minimum: 60mm/s; below 60mm/s, the filament gets too hot?, causing the layers to fuse too strongly, resulting in a very glossy and inconsistent surface. This is particularly noticeable with small models
The optimal print speed for the best layer quality is around 155mm/s.
Cooling: 80% fan speed for supports, and up to 100% for the part cooling fan.
Stringing: is present. Retraction settings (copied from the Bambu PETG preset) are at the default values.
This is my initial calibration. However, I’m still struggling with over-extrusion starting at around 170mm/s, which gradually intensifies up to 220mm/s.
How could I get this under control?
You can get Elmers Glue stick on Amazon.de, its what I use when necessary but not been needed on the textured plat I use for Sunlu PETG (mostly Black or White)
On the bare textured plate, no glue, I always let the plate cool down and prints just pop off with the smallest bit of flexing in both directions. When hot its a different story.
I’m new in the 3D-printing world with Bambu A1. My head is exploding from the plenty of parameters.
Yes, the question is not about concrete settings, but about the test/calibration sequence, to determine the optimal settings.
These steps, you described, are enough for new filament?
Thank you!
what about Inland PETG I used it and the ground layers don’t get to the wall, they stop about a couple of centimeters and get dragged by the nozzle, so what settings (or just what to do) do I use?
These are my settings.
I have zero stringing and no issues at all while printing. now i have to mention i made some modifications to the printer and i don’t know if this is a reason too(High Flow ObXidian™ HotEnd 0.4 and BIQU Panda Jet Head Cooling Fan Duct)
Hi everyone,
Complete noob here and happened upon this topic to try and get my Sunlu PETG printing nicely on my newly acquired A1 Mini. I honestly thought I would just be able to print and go, but fastly finding out there’s a lot more to it.
I’m having massive stringing issues and poor prints, so followed the advice I found here and the spools have both been baking in the oven for 10 hrs @ 60 celcius today, but still the problem persists when I print a stringing test print (four columns amidst a square base plate). I’m struggling with what I need to change, but going to try whats suggested here, although my next points are maybe where I’m going wrong?
I’m currently using Bambu Studio as my slicer, just because that’s what I ended up with from setting the whole thing up, but notice most in this thread are using Orcaslicer, as the settings mentioned aren’t available in Studio. Should I ditch Bambu Studio in favour of Orcaslicer to really be able to dial in my settings?
Thanks in advance and apologies for all the questions.
Scott
Be aware tht the standard Sunlu PETG prints quite a bit different than the Sunlu HS PETG, which prints amazing. It even has a max flow rate of 43mm^c/sec, at least by my measurement. Far better potential flow than even the Elegoo Rapid PETG.
First thx for all the input… i read a few of your post by now.
just looked u up on makerworld to check if you by chance uploaded your tolerance test. Any chance you could do that and may even explain how to use the data and enter that in orca slicer? Appreciate your efforts
lol my fans are mostly turned off, only for overhangs the head fan runs up a bit…havent had any warping or other issues aside from a little under extrusion, SUNLU PETG black printing at 250 first layer 245 next layers.
Tried your settings and my prints are coming out flawlessly now! Would you mind sharing your settings for PLA as well?
Have you had any issues with overhangs and bridging.
minimal roughness, and some sagging if cooling is not able to follow. but in general results are very good, although I have been getting better results with Tinmorry PETG Eco. smoother and shinier.
Just a head’s up that Sunlu is migrating toward using black tape to affix the end of the filament against a cardboard core. Apparently this is a bid to be bambu compatible, dating from when Bambu did that (before Bambu itself changed the design to use a different tape and configuration). There’s a lot of old inventory out there, so no telling whether you’ll get the old version without this nonsense or the new version with it. Why does it matter? If the black tape gets sucked into the AMS, if you’re using one.
For Sunlu PETG HF:
I finally got good results
Filament:
You may want to ignore my flow ratio of 0.8484. I did a manual flow calibration
Density- 1.28
Flow Ratio- 0.8484 (my own manual calibration in the device settings)
First Layer and All Layers- 235 degrees
Bed temp- 70 degrees
Max Volumetric Speed- 8mm/s
Cooling:
special cooling settings- for first 3 layers, fan speed 0%
min fan speed threshhold- 10% layer time 30s
max fan speed threshold- 25% layer time 25s
Keep Fan Always on- no, unchecked box
Slow down printing for better layer cooling- yes, check this box
Min Print Speed- 20mm/s
Cooling overhang threshold- 50%
Overhang threshold for participating cooling- 25%
Fan speed fo overhangs- 90%
Pre start fan time- 0s
Auxiliary part cooling fan- 0&
Setting Override, Retraction:
length- 0.6mm
z hop when retract- no, unchecked box
retraction 30mm/s
detraction speed- no, unchecked box
extra length on restart- no, unchecked box
travel distance threshold- no, unchecked box
retract when change layer- yes, check this box
wipe while retracting- yes, check this box
wipe distance- 1mm
retract amount before wipe- no, unchecked box
