What do you think is the best starter printer
Welcome to the forum.
The best start printer in my option is the A1 mini. It’s priced so that you can try out 3d printer without having to invest a lot but still prints really well. If 3d printing is a hobby you really enjoy you can move to a bigger printer at a future date.
I was originaly going for the mini, but the full size A1 doesnt cost too much more for a bigger build volume. It also depends on if you want the AMS light for multi-color printing. If you’re printing small multi color trinkets, then go for the mini. If you’re more into printing your own CAD designs for use around work/house, go for the a1. It also depends on if you’re wanting to use engienering filaments, in which case you would need a enclosed printer.
For an open frame printer you can’t go wrong with A1 or A1 mini, end of story. Even one and a half generations old, they still are top of the class.
For an enclosed coreXY printer it’s less cut and dry for entry level, but you should look at the Bambu P1S/P2S or Elegoo Centauri Carbon.
Ello,
I started with the A1C (A1 Combo), very good so far, I’ve had it for a year but if you’re looking for just a small one and you’re on a budget, the A1 Mini is by far the best street to go down. If you have a business and need 3D Printing necessities I’d suggest the P1S or P2S if you aren’t on a budget.
Look, I run a business and have the A1C which is perfectly fine, but keep the windows open when printing, keep the printer away from the window/not infront so the bed temp doesn’t cool down mid print and the print comes off. (definitely foreshadowing here)
If you’re on a budget, I’d stick to the A1 Series, A1 Mini Combo or not, is probably the best way.
For first time and hobby user’s like myself, The A1-Combo is a good start.
