Big job. Light work. Bambu Lab R1 is here
Has anyone seen the price of the CO2 replacement “tube”?
Way better options guys… Way better. Another toy laser
Wait for a bit longer, and, eventually, the price will drop to a more reasonable number… or you can always acquire a second hand… I imagine in a few months you may find the R1, at a discounted price, in some areas.
I have dreams of making cabinets without having to learn to cut wood with power tools, or pay some ridiculous amount to have it pre-cut, or have one the random local workers mis-cut it by 2-3mm because they aren’t joiners.
Is anyone able to confirm if this fits trade sizes of sheet wood? How serious are they about the maximum width? Standard 1/4 panel here is 1220x610mm.
Like, it says “furniture scale 3 meters x 18mm” in the advert, and what else are you using 18mm thick wood for?
They don’t have such info, yet. 600×3000mm “working area” With Conveyor, but no words on max accepted stock width.
The specs/release info is pretty sloppy. They are confusing 18mm Solid Walnut Wood (it can cut) with 18mm Plywoods (it cannot cut in one pass. probably 12mm at most) amongst others.
Interestingly, I just looked around the internet and I can’t find much data for using laser cutters on MFC (Melamine Faced Chipboard, or the wood that Ikea bookcases are made of; vinyl-covered MDF is also popular here). Everyone is just cutting plain wood.
Back in UK I have a garage full of vinyl wrapped chipboard furniture panels, and the iron-on edging strips.
MFC furniture panel, stock photo
Chipboard, yes (might char). Melamine lined MDF, yes, tho double sided can be tricky in one pass. Irrc Vinyls are PVC based, hard no for lasers. Some box store plywood with the wrong resin also won’t cut.
These kind of stuff with high amounts of glues and resins is harder to laser but I imagine CNC routers couldn’t care less. Much better suited for thick stocks.
Time to get used to laser machine bs marketing lol, furniture scale, but not furniture grade particle boards. And over there with Creality shamelessly advertising clear acrylics, metals and glass on a 10w Diode
Thank you. Your 2 messages have been helpful; there is much I do not know about laser cutters.
Already seen 2 advert videos in this thread described as reviews. Manufacturer supplied product, special agreements to receive it early, etc etc.
edit I think the machine I need for cabinets is a CNC.
edit The price of large CNCs … eek! It’s actually cheaper to order bespoke furniture from a specialist. Or go to woodworking school :slight_smile:
edit Actually plain MDF could work if painted
I don’t think I would choose this over xTool p2s. Sorry but I don’t see the benefits. Maybe when the 2nd gen comes out in couple of years
I think that has several reasons, or at least speaking for myself, I have several reasons to avoid chipboard in traditional woodworking, but many of those apply to laser cutting as well:
  • As a hobbyist, It is very difficult to achieve the quality that you are used to from industrial manufacturing like Ikea, especially with regards to the edges. plain wood is far easier.
  • For me, Particle board is inferior to wood in many respects, e.g. durability, aesthetics, stiffness, visual impact of small damages, and more. in combination with…
  • My most valuable resource for my hobbies is time. When I decide to spend it on creating furniture, I really don’t want to save some pennies to have a cheap looking result in the end.
  • particle board is much harder on the tools due to it’s high content of glue, which is very abrasive. Industrial manufacturing only uses diamond cutting tools, because carbide wouldn’t hold up long enough. The same glue is probably far more unpleasant in laser cutting compared to wood.
So the only advantage, that particle board holds is its low price in my opinion and the reason why they are not much talked about.
I’m not so disappointed. I think they started with a highly capable machine. And less expensive ones with fewer bells and whistles (eg conveyor system, rotary system) will come later.
I give it three years, tops, before they have a competitor to Xtool’s $600 machine. Probably less.
Singapore does not really have a strong DIY industry as the government will do most repairs, and cheap foreign labour will do the stuff they won’t. The UK, however, does, and I can tell you that MDF and chipboard (particleboard) are SUPER common for home made furniture. I suspect it’s because houses are brick or stone, which means wood is not used for structure (beyond roof triangles), which means the UK doesn’t really have a strong carpentry tradition or appreciation of timber beyond high end furniture.
EDIT I did not think there is any real problem with cutting MDF or chipboard with traditional tools, except for MDF dust which gets everywhere. Have you had issues with MDF and glue on your saws?
edit corrected particleboard
BambuSuite 1.5 now released. Bambu Suite V1.5.0.00 Release Notes | Bambu Lab Wiki
Still very much the same. Just with R1 features pilled on… scattered everywhere. I feel like I’m having a seizure watching these UI salads.
If BambuSuite simply copied xTool Studio, it would have been a massive step up - well organized, intuitive, simple workflow; If BambuSuite simply replicated BambuStudio’s layout, it would have been equally great - design and parameter in the same view, well organized.
But they wouldn’t. BambuSuite had the polish of xTool Creative Space 1.0 (old name) 4 years ago but disorganized with a counterintuitive workflow for maximum friction. Not because they had to. WeCreat’s app is a xTool clone and as far as I can find xTool (Makeblock Co., Ltd.) holds no interface related patents. Good news. Nothing is stopping Bambu. It only took xTool 3 years to have a good app, and Bambu is not totally starting from zero.:man_shrugging:
I do think BambuStudio did a good job streamlining PrusaSlicer’s UI and eliminating learning curves… but that might not mean anything here, most likely separate software teams.:man_shrugging:
Neat.
For folks that want to make furniture
Particle board is a posh name for chipboard which is made from wood chips. MDF is MDF and is made from wood fibers.
You do not want to cut MDF or particle board with laser because it contains formaldehyde. You even need special incinerator to use it as fuel.
Seems like they also launched an E1 filter?
New EU regulations control the amount of formadeylhde in MDF and paint. In the UK, which is no longer part of the EU, most of the newer products are made to comply with this regulation to allow export, or are imported from the EU.
You can still buy regular MDF in stores, but they will typically offer both types now.
edit You’re correct about particleboard; i get that mixed up all the time because of hardboard.
Some amount of formaldehyde in fumes is generally considered okay (won’t corrode machines and once well extracted safe to enter. For outdoor safety check local rules, but this should apply to the U.S.) with proper ventilations. Plywood, even some acrylics, all contain some amounts of them. “Laser-safe” / laser grade low-VOC sheets are also sold.
Pure solid wood will be the only thing that gets you ‘clean’ fumes but yay still a carcinogen.
(The right kinds of) Plywood, MDF, PMMA Acrylics, other PET based sheets are generally well established to be okay. Just never anything PVC based (57% chlorine).
I’ll also add that the operator should wear a respirator with formaldehyde coverage (like 3M 6006 cartridge, NIOSH approved for certain organic vapors, acid gases, ammonia, methylamine and formaldehyde) for proper protection, especially high fume sheets. They don’t say to not hurt sales but this should be kind of obvious when only ‘cleaner’, not ‘clean’ air were advertised. (Same for printing ABS)
The regulations control how much is emited from finished product I.E. panel/ board. They don’t control how much is released during processing. 0.062mg/m^3 is not much, but together with other aldehydes and resins used in those materials realising all sorts or carcinogenics I would consider them as unsafe for home processing with laser without adequate fumes extraction and PPE. Not worth is. As @illien said alternatives exist and PPE should be used around lasers.
