Hi, since the (EU) store is not updated yet maybe someone is interested in my support ticket result I had with Bambu Lab and am happy about the fast response from them!
In store it says: Without it, the camera cannot function with the Cutting Upgrade Kit for photo capture. Support for calibration without the Laser Module will be added in a future firmware update.
Thank you for contacting Bambu Lab Customer Support!
We completely understand your confusion regarding the store description and the wiki documentation.
To clear this up, yes, you can use the BirdsEye camera with the Cutting Module.
With the latest firmware update released, our system now supports BirdsEye camera initialization and calibration directly for the Cutting Module, meaning it no longer requires the Laser Module to function for calibration. You can safely follow the latest firmware guidelines and wiki instructions.
We hope this clears up the confusion! Please feel free to reach out if you have any other questions. Have a wonderful day, and happy printing!
I’ve now received the camera and installed it in my H2C, following this guide.
A few notes from the installation:
I couldn’t screw the small cable buckle clips in the orientation shown in the guide. Rotating it 90 degrees made it fit properly and hold the cable in place. I’m not sure how useful the clip is, though.
The BirdsEye menu appeared on the printer after I turned it on with the Cutting Module installed.
The installation took a little time, but was manageable as long as I didn’t rush. Connecting the cable to the printer’s board required some careful finger work.
I believe they’ll update the EU store soon, probably with the next round of product description updates.
To set expectations: From what I’ve explored so far, the camera can currently only be used to take a photo that is displayed in Bambu Suite. I couldn’t find any additional camera features in either the Bambu Handy app or Bambu Studio.
Here’s an example photo. You can see a snowflake, and if you look closely, you’ll also notice a square outline in the upper half of the paper from a previous cutting job, as well as a smaller one near the bottom of the A4 sheet.
The good news: This means you can reuse the same sheet of paper for multiple projects! You can cut, draw, reposition your designs, and cut again while making use of the remaining space thats what it is for.
Some Silicon Glue for reinforcing connections came with it. I am not aware what to do with it and didn’t need it. In manual it didn’t find any hint why to use it.
As well 3 those clip / buckles came with it, 2 are only described needed in manual. I guess if you mess one up or want to add 3 its for.
