Hello. I’ve been following the Birds eye camera for a few months, but it hasn’t been in stock. By any chance, does anyone have one for sale and would be willing to send it to me by courier? I live in Romania, Europe. Thank you very much!
Same. Although i don’t think that anyone would sell only birds eye camera. I know that some people bought laser upgrade kit discounted to 350 euro (easter promo), just to take birds eye camera from that and use it with cutting module. Does anyone know when birds eye camera will be avaible for purchase?
The bird’s eye comes in and out of stock. I was able to get one on March 30. You just have to monitor it or put in a notification for in stock drops and snag it quickly.
I have one, but unfortunately I’m only willing to ship in the US.
The camera was never available; I waited so long. I think Bambu prefers selling the laser upgrade kit. That’s why I bought the 10-watt laser kit for €345 for my H2D, just for the camera.
While I was checking online, there is a supplier which might have the camera in stock.
Just to let you know over here.
It’s a requirement for the laser and somewhat helpful with the cutter.
I cut out rounded rectangles in a very specific shape after printing and the print-then-cut feature won’t work for my workflow. The birds eye has been instrumental in getting a good line-up, and some bleed on the print solves the rest.
the birds eye camera are back in stock on the UK site
I just installed a birdeye camera on my non laser H2D. When turning on the printer it seems to do not notice the camera. I’m looking for "BirdsEye Camera Begin Setup” in the toolbox menu. Can someone who did the same confirm that this setup option does appear after installing? Did anyone had a similar issue and solved it?
I have the latest firmware version installed v01.03
Einfach das Schneidmodul anbauen und dann wird die Kamera kalibriert, vorausgesetzt sie haben diese korrekt eingebaut.
Thanks, I kinda expected to show after installing the camera. Didn’t think that i also needed to install the cutting module first. Thanks for your quick reply @KK2023
Good morning. I had the same problem. If you’ve installed the camera and there are no settings in the menu, then the cable isn’t installed correctly.
You can also just start Bambu Suite there should then be a pop up that the camera is not yet calibrated. Then it’s installed correctly but we’ll no firmware at all.
I tested this on my H2D and H2C non laser. Both are retrofitted the camera.
The cable was installed correctly. I just assumed to see it installed on the h2d screen directly. But it is not, until you install the cutter unit. That’s what fooled me.
31
Thank you for your answer. Top
