BL, please reduce the excessive space requirements for the “By object” print sequence.
The printer knows exactly where each part is, so it should be able to avoid collisions. The printhead can also move up and down. I can understand why taller objects might require more space, but I don’t see why this is necessary for parts that are only a few layers high. At the moment it seems like everything above 5mm trigger the massive space requirement.
BL, please improve this so we can make full use of both nozzles.
As you said, the implementation of print by zone treats the part’s maximum perimeter as a constant cross section column, and the extruder head as a constant cross section column as well, and simply adds the extruder’s radius from the nozzle to the edge of the extruder in a given direction to the part column to come up with the shapes - it’s the simplest possible implementation and leaves a lot of room for improvement.
Ideally, actual 3d space allowance calculations would be implemented, (not holding my breath on that one), but to your point even if the extruder’s required clearances got sliced into two, so “below X height” parts could be printed using the actual needed space.
You can override this by just ignoring it and using the print sequential feature anyways, however that’s then on you as the user entirely. I just did this with some scanner marker cards which were like 2mm (ish) thick and it was fine, but I physically measured the clearance between the cooling shroud and the bed before I started the print.
That said, there’s no reason the software can’t be built to handle it. It would need to know the precise specs of the print head though, so it would need to be implemented by the manufacturer (or at least they need to actively participate in it) for best results.
After my current print is done, I think I’ll scan my H2C toolhead to see what it’s actual clearance requirements are. Will report back with my findings.
If you peek over to Cura, they have solved that much much better.
Cura takes into account the actual sequence, so when one part is printed, it doesn’t have to take into account the print head movements for the already printed parts. It also takes into account the extension of the printhead into each direction from the nozzle. I don’t know how to describe it better, hope it stoll gets clear.
Anyway, that allows for a much tighter packing than in BambuStudio.
Something that Prusa Slicer & Bambu Studio really could carry over.
I just tried it again and it behaves differently than what I described:
Even the guard areas are not allowed to intersect. In Cura, only objects have to be outside other object’s guard areas.
It looks like the guard area extends the same distance from the object outline in all directions although the nozzle doesn’t sit in the centre of the print head. Especially the rounded guard area at the object corners doesn’t make any sense at all.
This is trying to place 3 cubes with 40x60 mm in BambuStudio for an X1C:
This is the same in Cura. Sorry for the several years old version. I have reconfigured the build plate size to match the X1C to eliminate different scales.
See how the guard areas are different in each direction from the part, according to the position of the nozzle within the print head. In that case, the nozzle sits a bit left in the print head, so more clearance is needed to the right.
And not only guard areas can intersect. the middle part is even allowed inside the left parts guard area, because the middle part doesn’t exist yet when the left part is printed. Only the left part has to stay outside the middle parts guard area.
Seems far more sophisticated, and that is a 3 year old Cura version and it worked like that many years before.
Not knowing the specific dimensions of everything involved it is hard for me to make any assumptions based on those photos.
There’s two cases I think.
The nogo zones are accounting for the overlap. This would imply that the tool head is much wider than the actual visible space shown and the zones themselves would not be allowed to overlap.
They aren’t accounting for it, and thus overlapping so long as that zone does not touch the other part would work fine.
If I am understanding your point correctly here, one would have to look at the information the slicer is presenting to identify which case it is. That said, once known you can use it how you like, as bambu will let you choose to ignore those areas and proceed to print anyways.
What I am unclear on is if the software accounts for z height here. If not, then it’s a great way to knock the taller parts off the bed with the linear rails.
Yes, you are absolutely right that we don’t know how BambuLab calculates the nogo zone from the print head dimensions.
What makes me really suspicious about the BambuLab zones are the rounded corners. To me that makes zero sense when the object and the print head have a rectangular footprint. And the equal distance to all sides also smells more like “let’s roughly estimate the space needed and slab a huge safety margin onto it”.
I often made the experience that if something doesn’t look very smart, it rarely is too smart for me to grasp it but usually is just plain simple.
Regarding z height: I think there Cura and BambuStudio behave identical: the build volume is reduced in z so that the parts don’t reach the gantry.
It makes perfect sense - when you trace the outside perimeter of a square with anything with a thickness, the outside of the traced shape is a square with rounded corners.
Sure but that is not what you need to avoid collision. Take a rectangular object and a rectangular print head. Then move the printhead around the part so that it just doesn’t hit it. While moving the print head, draw a line where the nozzle would be. This line + maybe a tiny safety margin would be the optimal guard zone. I will later draw a sketch that makes it very clear hopefully.
Thank you! That makes it very clear. They just assume a circular guard zone around the nozzle with just the single parameter “diameter”.
Cura gives you four values +x, -x, +y, -y that tell the slicer, how far the print head extends from the nozzle in each direction.
When the parts are short enough, you can really pack them in. These are all 3mm high on a P1S. I was amazed that it was smart enough to allow this. And also a little nervous that the fan shroud would collide.
