Clean your plate with warm soapy water and maybe also check the screws holding the hotend heating assembly, those like to back out on their own and then the whole hotend just wobbles arround and can cause failures like this.
Known problem of the A1 Series
I’d clean the plate but the whole printed area in the photo looks rough.
I’ve also seen PLA do this kind of thing when moisture is too high. If cleaning the plate doesn’t fix it, I’d look into drying the filament. Depending on your local humidity and how you store the filament it could just be water making the print especially vulnerable to contamination on the build plate.
