Can someone open this and see if you get errors?
Hi,
I want to make this Chess set as a Christmas gift: Harry Potter Chess Set - COMPLETE SET - Free 3D Print Model - MakerWorld
When I open it in Bambu Studio on my laptop, before I even slice it, I see a bunch of errors/warnings in the Objects section. This is on the Characters item, not the chess board item. I have a A1 if that matters.
Screenshot: Imgur: The magic of the Internet
Can someone else open it and see if it does it for you as well? Just trying to figure out if it’s something I’m doing wrong or if there’s something weird with the file, and how to fix it if it is.
Thanks!
I was able to open all of the files with no errors. I am running BS 2.4.0.70
I’m also on 2.4.0.70. Is there anything that would cause me to get all those errors on the left side under the Objects tab? Do I need to reset something maybe?
Those are non-manifold warnings. you can use the windows repair tool by right clicking the object and choose fix. Otherwise the item should print fine. I ran the repair tool and the object was fine after slicing.
I’m mainly concerned about the ones that say the item is not on the print bed. When I click it, the item physically shifts up slightly. When I look from the bottom, I can see that the items are actually below the print bed for some reason.
