Cannot get filament mapping right
Hi
I’m new to 3d printing, so I’m probably missing something. Im trying to print a project from makerworld with my x2d/AMS 2 pro combo using Bambu Studio. The AMS holds 2 spools of PETG BASIC and 1 spool of support for PLA/PETG. When I’m trying to print I get a message that the’s something wrong with the mapping:
The spools were all automatically identified by the AMS and I synchronized the filament list from the AMS.
These are the filaments I chose in the support settings:
What am I missing?
Bambu Studio wants you to put the support PLA into the aux extruder. It substantially reduce the number of filament changes and poop. Is there a reason you are not putting the support PLA in the aux extruder? This is what the X2D was made for.
If you really want to leave the support PLA in the AMS, then you’ll need to select the “regroup filament” button that can be seen in the first image you posted. Select “custom”, and then move the support PLA to the main extruder.
And that was the (obvious) thing that I was missing. Thanks!
One other comment - If your “support PLA” is the Bambu support filament, then I’ll just say that its value is not that great. Regular PLA does a pretty good job as support interface for PETG. $35/0.5 kg for the Bambu support filament is surprisingly high. Granted it will last a really long time if its only ever used as interface material, so maybe its worth it? For very complex prints such as figurines that need a huge amount of support, maybe it is worth it.
But also if you do use PLA support for PETG you may get clogs and warping and some other issues. From this perspective as you will use very small amount of support material using the bambu ultra expensive filament is not so bad idea. As you may find clearing the blob with this head is not exactly easy thing.
