Cannot rate "failed" prints 5 stars
I had a long print “fail” at 100% and now I can’t rate it highly. I’ve had this happen more than once. The filament failed to retract at the absolute final retraction after the print was done. It is not the fault of the designer at all…and the model turned out fine, but I can’t rate it because it “failed” and I had to cancel it so I could manually retract the filament. It’s kind of dumb I can’t upload a photo of the finished print and override this “cannot rate failed prints 5 stars” thing. Maybe pressing cancel after 99.9% of the g-code is executed should not count as a “fail” particularly if it’s uploaded with an image of the successful print.
Similar to this, if you have an early failure (say bed adhesion) and you restart the job from the printer’s control panel - you cannot rate the print because Makerworld does not know about it.
Glitches etc, I’ve always rated and when this happens I will comment at least and depending on the model BOOST it if worthy. It isn’t a great loss at the end of the day.
I’ve had this happen, usually just leave a positive comment and an explanation. I don’t want to give 3 stars because it will lower the average.
