Hey @AeonJoey
I’ve been running into similar issues with my P2S(s) and H2S too. Looks like the latest posts here were way earlier in the year… just curious if you’ve found any type of solution or better approach that has helped? Thanks in advance! ![]()
Hey @AeonJoey
Hey there, actually no, I’ve gone more rounds with Bambu support - and there’s never been any advice other than “start with this new set and iterate off of it until you find the settings that work for this model”. Meanwhile I now have 10 X1Cs doing ironing identically in any and all shapes and area sizes regardless of detail. I won’t bother responding to the know-it-all above. I have a business to run, a solution that is one size fits all (the X1C) and so I’ll check in now and again to see if any advancements have been made towards ironing predictably on the G2+ printers. But none has. This is wholly evident by the Bambu Lab WATCH project that they are using to promote the H3C, that watch has some nasty top surfaces - without ironing, which tells me they couldn’t get it working either.
There has been one strange anomoly though that so far has no explanation- Bambu Stufio 2.9.1+ now tells you to slow down top surface speed to 100mms for ironing… on every printer regardless of model, or nozzle type, or nozzle size. I tested again, and there was a shift in the window of results but nothing repeatable, so I gave up. I tested with the X1Cs and there was no difference.
You’re probably interested in checking out this thread - it’s much more up-to-date than this one. There you’ll find tons of questions, answers, and tutorials.
Even though the topic is specific to the X2D, what you learn there is universally valid to every printer.
I didn’t see this post earlier but it highlights one of my main frustrations. The user above is getting great results with an X1C but the new machines that should be an upgrade, can’t reproduce the quality of the older machines.
