any solution for this ? im facing the same problem and my printer is useless for 2 weeks
Have you tried using a different SD card? A failed SD card can cause this issue. Be sure to use the Printer to format the card (Fat32).
I had to reinstall Windows, and after that, I also had a problem sending G-code via the cloud service. Everything worked fine before reinstalling Windows. But in my case, the problem is related to reinstalling the operating system. I installed Bambu Handy on another computer that is connected to the same WiFi network, and there the G-code is sent to the printer via the cloud service without any problems. I’ve been looking for a solution to the problem for two days, but so far without success.
Rename the printer, or if you have more than one printer delete the printer above your app. This solved this problem.
Having the same issue, cannot print on LAN and the error is says is that the Bambu Studio says it cannot find the storage device, tried reformatting on the P1S, reformatting on computer all with Fat32 and all 32 gig cards or 16 gig cards, none work, im really stumped…
I don't know if it's the same problem, but it helped me
open command prompt (cmd) as admin:
type this:
certutil -generateSSTFromWU roots.sst
certutil -addstore -f root roots.sst
the problem is still with "storage test failed" but sending the project via the cloud works for me
Thanks for this. Now I can send prints through the cloud!
