Chamber Temperature seems to be missing from the latest Bambu Lab for X1C. I can even search for ‘Chamber’ and it comes up with an entry but jumps to where it should be (under heading ‘Print Temperature’) but it’s not there! Anyone else have this problem?
As eno stated, there’s no way to control chamber temp on the X1C. I’m assuming you want the chamber temp high for better results with ABS printing. What I typically do is, before printing, I manually set my build plate to 100C and manually turn on the auxiliary (not chamber) fan. I then let it sit for a while with the chamber fully closed, maybe 20 minutes. With the plate generating heat, the auxiliary fan circulates the heat throughout the chamber. This brings my chamber temp up to a max of about 42C, and then I start my ABS print. This has worked well for all of my prints, hopefully it helps you too.
