I’ve found MakerWorld’s rating system frustrating for a long time, especially the emphasis on rating the print profile after a print.
Intuitively, when people see a 1–5 star rating on a model page, I think most assume it represents the quality of the model itself. But on MakerWorld, what you’re mainly encouraged to rate is the print profile.
That seems like a strange thing to give a 1–5 star rating to. For most users, the assessment is probably basically:
It printed properly.
Something went wrong.
How many users can meaningfully explain the difference between a 3-star, 4-star and 5-star print profile if the print itself completed successfully?
A print profile feels much closer to a pass/fail question: does it reliably produce the intended result?
The problem is that the rating becomes noisy in both directions.
A perfectly good print profile can get blamed because someone used wet filament, had a partially clogged nozzle, poor bed adhesion, incorrect filament settings, or a badly maintained printer.
But the opposite also happens: people rate the print profile based on the quality of the model itself. You see ratings mentioning things like poor fit, awkward tolerances, weak functionality or bad design decisions. Yet the profile may have printed the model perfectly to specification. If the designer intentionally made something loose-fitting, or simply designed it poorly, that is a model issue, not a print-profile issue.
So the profile rating ends up mixing together several completely different things:
Whether the profile actually printed successfully.
The condition and calibration of the user’s printer.
Filament quality and moisture.
The quality of the model’s geometry and tolerances.
Fit and assembly.
UX and ease of use.
Functionality.
How well it works for its intended purpose and real-world scenarios.
Aesthetics and general design quality.
At that point, what does a 4.3-star “print profile” rating actually tell me?
Meanwhile, those latter things are exactly what I would like to know (and rate) about the model itself. Is it well designed? Is it intuitive to use? Does it function properly? Does it fit as expected? Does it work well in the scenarios it was intended for? Is the description accurate? Would I recommend it?
I think MakerWorld would be better with one clear overall rating for the model/download, where users can take the whole experience into account.
If Bambu Lab still needs feedback specifically about print profiles, that could be a separate, simple question such as:
“Did this profile print successfully?”
Yes / No.
That would produce much cleaner data than trying to make users assign 1–5 stars to something that is largely binary.
Right now the star rating communicates something different from what I think most people intuitively believe it communicates, while also mixing several unrelated judgements into the same score.
