Changing start G Code "no wipe no purge"
Hi all, I’m looking for a way to remove the brushing and the purge line from the start up sequence. I know where the G code is located I’m just unsure of what to remove or “comment”. I don’t want to prevent the start up from doing anything else ie. the vibration check or the bed levelling. The purpose of this is a specific print requirement and is not to replace standard running of the printer which will have those things still.
My big question here is if I remove or comment the section marked “wipe mouth” and “extrude cali test” section will it effect anything else at all? Is there any part of those sections or any others that would have to be removed or not removed?
