CHT nozzle adherence issue PLA
Genuine heatpad … There’s something related to the nozzle… I’ve swapped to genuine bambulab nozzle kit without calibration and it stuck to it.
thats good to hear some validation that the nozzles at least work. I wanted to get them because sets of replacement nozzles 3 and 5 packs can be had for around 10$, which is better than bambu’s price for a single one. What are you using to unscrew the nozzles tool wise, and have you found it to be a drop in replacement or did you need to adjust for anything? I don’t know if any one has done it but I wish there was a dedicated aftermarket nozzle thread we could go to discuss success/failure/tips with replacement nozzles
I went though a bunch of tools and settled on a 4mm and 7mm drop forged wrenches as well as a 4mm box screwdriver. Both were just a few dollars on Ali.
Just DONT buy one of these in box 4mm. I tried one as I have an allen screwdriver set and it works great, but with the box 4mm drivers you can not put enough torque on it as the shaft of the drivers is connected to the handle with a grub screw. When you try to screw down the tip is just slips as there is quite a bit of torque applied.
And yes the nozzles are so cheap at $2 that when i get a clog, i just toss it. But i have recently switched to running 0.6mm nozzles and my prints look just as good with 0.12mm layer lines and clogs (with silk and CF filaments) are a thing of the past and also the speed increased is nice. I would not go back to 0.4mm unless it was a tiny item with text.
I’ve been down this road before. This isn’t a perfect example, but especially as you get to the smaller diameters, you want a thicker shaft up until it gets to the business end of things, or you’ll end up twisting the whole thing when you torque it, especially if its long:
https://a.co/d/9sGUcCT
They’re a lot harder to find though, because it’s cheaper and easier to make them with thin shafts.
Thanks, I think I’m gonna try to grab something similar. When you actually screw/change the nozzle, are you heating it up and then unscrewing the nozzle with the hotend still in place on the toolhead?
Or do you heat it up, remove the hotend from the tool head and place onto a heatsafe surface of some kind, change the nozzle there, then replace the hotend and heat it up again for final tighten before printing?
My worry is that it would be too easy to overtighten the nozzle and put torque onto the toolhead or stress on the screws that hold the hotend to the toolhead. what is your experience with nozzle changes, does the nozzle screw/unscrew easy enough that stress on the toolhead is not a factor?
So here what helped:
HOT water with disk washing, dried with microfiber.
Cleaned with rubbing alcohol.
Then Plastic repellant on tip.
Sticks as glue now!
