Clogged ASA nozzle
Can you help me?
I can’t manage to print with (ASA Bambu Lab) using the filament settings provided by the machine. I’m now on my second spool and already have 8 clogged 0.4 nozzles.
PLEASE help me, thank you.
Nowhere near enough detail for anyone to say anything. What printer, what nozzle, what actual temperatures, what actual error was reported, what did you do to correct the problem, and most importantly what makes you think the nozzle is clogged (vs some other issue)?
Nozzle rarely get clogged up. More often than not, the problem is with the extruder drive mechanism. If you’ve had a problem with 8 nozzles, something is wrong with your machine or something is wrong with what you’re doing with your machine.
More details.
Is it ASA-CF or -GF or something? Those particulates are sometimes hit and miss on a 0.4 nozzle, you unfortunately get to find out per spool lol
Unless you mean like a heat creep clog or something. And then more details plz, ideally share the 3mf
Decrease the volumetric extrusion value in filament settings. I changed from 25(?) to 15mm3/s and had no more clogging.
