Color mixing
I’m trying to use this filament mixer with my A1 and AMS lite. The first plate printed no problem but when feeding the printed filament back into the machine to extrude again I keep getting an error that the filament is slipping. However, I’m able to manually load and extrude the printed filament no problem, it just won’t load when I’m running a file with it.
I’ve tried loading it manually then running the file but it automatically reloads and then starts slipping again. Is there a way to fix this or some kind of override I could use to make it print with the loaded filament without reloading?
The extruder isn’t clogged as it can reload a different filament color and print no problem after attempting the mixed color filament.
multicolor filament as spooled and manually extruded
