I need help everyone; I can not figure out how to fix this. When i fcolor the model the color goes into the infil. See the image below. i just want the color to be at the surface of the print.
For better or worse, this is how Studio applies colors when painting a model on the sides. It always tries to have the painted color embedded/extended towards the center of the model. Makes the model very solid but often not efficient to print, especially due to the extra internal walls being added all over the place. There’s no way to change that (though reducing wall count overall can help).
If painting only the top or bottom of a model then there’s the “paint penetration layers” setting in Strength. But that doesn’t apply for anything painted on vertical surfaces.
For organic or complex shapes there isn’t really a good workaround that I know of. There are alternative ways to generated painted/colored models online (eg. HueForge), but I can’t recommend any specific one at this time.
The alternative that works well for some projects, like drawing text or logos or functionally distinct regions, is to model the separate colors/filaments as separate bodies in CAD, then assign filaments to those bodies directly in the slicer (no painting). For organic shapes this is often not practical.
-Max
thanks for the reply i was worried that there wsa not much i can do about it. I wanted to check that i wasn’t going crazy and just missing a setting. I even tried to imbed a simple shape into the center to try to override the painting but it seems like the painting over road the simple shap i added. I also just tried the lower wall count and it didn’t change it enough to make me want to change the wall count. I’m not a programmer but that would be a nice option for Bambu Lab to allow a x number of layers into the model that we could adjust.
