Configure .3mf file options when using .scad generator
When editing your model with a .scad file, click the little icon to the left (middle of “thumbnail”)
This will open up the Parametric model maker, but in a “creator mode” when you will be editing the uploaded data.
Then click on the gear icon in the top of the preview section.
This should pop up a dialog where you can configure some settings (not everything possible in Bambu Studio)
You might need to click the “Upload” button in the upper right corner when done to save changes for others on your model (I can’t remember if that is needed).
I think this is the way to customize print settings for .3mf files out of the Customizer.
