Connector blocked by silicone glue
The P1P connector has silicone glue on the pins (terminology?) from when I used glue to connect the toolhead cover clip to the connector board. Has anyone had this issue with a successful resolution?
Remove it with some tweezers if you need to undo the connector.
I’ve tried using ISO first to remove it with tweezers as well as a fine tip sewing needle, but the residue is hard to get off. I’ve used a hair dryer to loosen the glues grip, but not with a satisfactory result. Anything else from someone that’s had this problem?
