Constant "I am not a robot" prompts
Ah yes, the toast master club. Sadly I never qualified, but I almost made it out of the Milk into the Melba group. So close..
I have had this happen a couple of times, I also always keep the tab open and do not use a VPN. I think it is when I download several models in a short space of time it triggers it. It is annoying but stops in a couple of hours.
A lot of comments with possible reasons here. I did read them but I did not see anything about the web server. I have nearly 40 years experience in back-end web dev, desktop dev, blah, blah, blah. If your session were truly still active, a browser refresh shouldn’t trigger anything other than resetting the server’s session timeout variable. That can very A LOT. When I built sites that were behind a log in, the client would ask for anything from 10 minutes to 2 hours. Point being, your session will timeout and end if there’s no activity by the session timeout value. On the client side, there is no way for you to see what the server’s session timeout value is. Either way, it does seem that the session per user validation process has been changed on their end. There may not be a lot you can do, however, do this to refresh your browser. Press CTRL+F5 (hard refresh). That refreshes the browser and it also clears out client-side browser vars and elements - it works on all browsers (although I can’t vouch for Mac users; I’ve been PC all my life). It only applies to the domain your web page is currently visiting, and it does not erase any saved passwords, auto-fill values, etc. It simply is a more thorough refresh the the standard refresh. If that doesn’t help then I’m afraid you’ll have to live with it.
All of this was true probably 40 years ago.
These days, with the threat of constant attacks, DDoS, etc. companies are adding a lot of protection that sniff the incoming traffic and can drop the connection (along with active sessions if needed) if something is off. Some are more reactive than others.
40 years ago? Sure, dude. I was simply getting to the point of trying a hard refresh to see if it would help the op at all. Have a nice day.
I still think he’s just a robot…
Let the rumble continue.
For a while I was getting constant CAPTCHAs on Makerworld, despite not doing anything on the list of behavior that would trigger it. I contacted support, and after a bit of back and forth to convince them I really wasn’t doing anything to trigger it, they looked into it and got back to me a few days later saying “we fixed it”. I don’t know what they did, but it’s been fine since, so they clearly had something generating false signals. Might be worth giving that a try.
