i got this new p1s upgraded from an ender 3.
The first time I printed anything I did a benchy to make sure it was working good. printed nice. Filament was wet. Added the sunlu dryer, printed the top glass riser. Printed a few more things. All gorgeous.
Then I had an issue with a nozzle globbing and prints failing only a few days in.
swapped the nozzle and washed the bed with soap and water, printed great until last night when it started failing again.
Wouldn’t lay a nice first layer. Had some big bumps with strings . Nothing would stick. Took the bed back off washed it aa sec on time with a sponge daddy scour side using Ajax and hot water.
Still didn’t want to print right.
Finally swapped the nozzle back to the old one that I cleaned out /heated with a. Torch to clean the inside:
Did the same to this one to hopefully use it as a spare.
Printed a bed adhesion test. Came out prettt much perfect. Some very minor artifacts but nothing out of the ordinary.
Then printed a can opener. Printed okay. Too fast for some of the parts. Nothing concerning.
Next print was a storage bin. A tall square bin. Large contact area.
Failed , caused the blob of death and now I’m out $35 for a new hotend.
What’s the cause of this? This things causing me the same issue in less than two weeks even my ender 3 didn’t have this many issues so soon.
Any help is greatly needed and appreciated. I hate that I bought this expensive printer for it to fail so miserabley so much so soon.
As you can see this trash bag dispenser I designed and printed came out perfectly.
the one that failed.
this was the can opener
This is the can opener . Printed okay enough
This is the glob that ruined the hotend for good
